Arduino Code Generation doesn´t work | Arduino Compatible Compiler for LabVIEW Discussions | Forum
September 7, 2015
5:19 am
Im trying to generate Arduino Code from a simple VI but it doesn´t work at all.
I also tried an example vi with the same result.
A windows pops up for a fraction of a second and the compilier show the errors as you can see on the Picture.
Does anybody know what i´m doing wrong?
I´m using Arduino 1.61 any LV 2014 SP1.
Image Enlarger
September 7, 2015
2:31 pm
I believe you are trying to use the Arduino Code Display Tool option instead of the Compile and Download option.  Are you trying to build a user library or just trying to simply compile and download a VI to an Arduino board?  If its the latter, then use the Verify or Compile and Download options.  The "Arduino Code" menu item that I believe you are using is only for creating a user library and porting an Arduino library to LabVIEW.  This tool will only work for user created API VIs (refer to the Porting an Arduino library to LabVIEW section in the user manual).
September 8, 2015
6:09 pm
my mistake... thank you!
