Arduino Compatible Compiler Error for Set Digital Pin Mode SubVI. | Arduino Compatible Compiler for LabVIEW Discussions | Forum
August 27, 2015
11:05 pm
luvdeals2k
Phoenix, AZ
Community: Arduino Compatible Compiler Error for Set Digital Pin Mode - National Instruments <!----> <!-- -->
Hello, I attempted to recreate a Labview program for the Arduino MEGA2560 from Youtube. I am using Labview 2015 and the Arduino Compatible Compiler. I see the following error when attempting to compile the program. Does anyone know what this error means ? VI is attached.
I have tried this with LabVIEW 2014 and 2015.
"Running interepreter ............Error! subVI named Set Digital Pin Mode contains two or more terminals with duplicate names. Please rename the terminals so there are no duplicates."
When I open an existing VI within examples in the compatible compiled and look at the subVIs, these look quite different that I have from the Labview Arduino palette.
Is the error I am experiencing a version issue ?
Thank you.
August 27, 2015
11:22 pm
It sounds like you may be using subVIs from the LabVIEW Interface for Arduino palette (LIFA).  This is NOT the same as the Arduino Compatible Compiler for LabVIEW palette.  Please confirm you are using the correct palette set.  You can take a look at the included examples to help get you started.
August 27, 2015
11:38 pm
luvdeals2k
Phoenix, AZ
Hello Steffan,
Where do i download this Arduino Compatible Compiler for LabVIEW palette ? I am attaching screenshots of my labview functions palette and I don't the palette you have mentioned.
Thank you much.
labview-palette.JPGImage EnlargerVIPM.JPGImage Enlarger
August 27, 2015
11:40 pm
If you installed the compiler it will appear under the Addons palette.
August 27, 2015
11:43 pm
luvdeals2k
Phoenix, AZ
Awesome ! I see it now. Many thanks.
August 27, 2015
11:48 pm
Ok good.  Your very welcome.
Holographicmfq, Philanthropy_bySl, TommyHic, ArmandoPef, Marshalluzd
