Arduino Due serial 1,2,3 problem | Arduino Compatible Compiler for LabVIEW Discussions | Forum
October 22, 2016
2:32 pm
miche91
Forum Posts: 35
Hi everyone,
I am trying to write something on serial 1 or 2 or 3 port on in my arduino due board.
I would like to read this data through an FTDI (TTL to serial converter).
Obviusuly on Serial 0 all is ok, but when i use Serial open 1 (2 or 3) the system still transmit on programming port of the arduino and not on pin 18-19 etc, infact my ftdi converter doesn't receive nothing.
whats going wrong?
I attached a simple VI that I used to try.
thanks
Michele
October 22, 2016
10:05 pm
This is a defect in which if you do not wire the serial settings input, it will revert to Serial (port 0).  Wire up a constant to the serial settings input and it should work on the other ports.  This will be fixed in a future release.
October 23, 2016
3:20 pm
miche91
Forum Posts: 35
yes Steffan,
Now it work
thanks
Michele
