4:21 pm
All,
It appears Arduino has made a major change to how board properties are managed in the Arduino install in 1.6.2+. In 1.6.2 specifically they moved where the boards file is located (file that stores the information for each board which the Arduino Compatible Compiler for LabVIEW depends on). They have moved it back in 1.6.3. So be aware that version 1.6.2 will not work with the Arduino Compatible Compiler for LabVIEW.
Furthermore, their intended change is to make a plugin architecture for adding board support. So in 1.6.3+ you have to download support for the SAM (Arduino Due) targets manually through the IDE and the libraries and board information now gets installed somewhere else that the ACC4LV doesn't expect. So although the ACC4LV will work with 1.6.3, it will only work with AVR boards (not the Due).
We have decided to wait until Arduino sorts out how they are going to support new boards in case there are any additional changes that will affect the ACC4L. For now, please use Arduino 1.6.1 if possible.
Release notes can be viewed here:
12
