bitWrite / conversion of Boolean Array to Number | Arduino Compatible Compiler for LabVIEW Discussions | Forum
May 7, 2018
2:18 pm
AK7466
Hi.
I would like to use the Arduino bitWrite function, but have been unable to find a way to do this so as an alternative I tried to convert a Boolean Array to the corresponding number and this seems to be getting uneccessarily complicated.
Am I missing a simple solution somewhere?
May 7, 2018
3:42 pm
Can you confirm which VI you are using?  There is no bitWrite VI.  There is a Digital Write.vi which is for a single pin, and a Digital Write Port.vi which is for writing 8 bits at a time.  The latter is probably what you are looking for.
May 29, 2018
2:51 pm
AK7466
Hi Steffan.
Thanks for the prompt reply.  Sorry for the delay in getting back to you.
It is not the "Digital Write Port" I want to use, but the "bitWrite" and "bitRead" functions which appear in the Arduino language but do not have a corresponding LabVIEW function.
What would you suggest as the simplest way to implement this?
Thanks.
May 29, 2018
6:24 pm
If you are operating on a variable/wire, then I would think you could easily do this with LabVIEW primitives, like and AND gate, and make it a subVI.  Those functions just write and read a single bit in a variable.  If you are trying to write/read to and from a digital port, possibly for speed, you could make a custom library to wrap the bitWrite and bitRead Arduino functions.  Take a look at the help manual for instructions on making your own library.
May 31, 2018
8:20 am
AK7466
Thanks Steffan.
I will give both of those a try.
