cannot get simple example sketch running - analog input temperature vi | Arduino Compatible Compiler for LabVIEW Discussions | Forum
December 12, 2016
2:09 am
hib
Please suggest a way to get me up and running with the home version demo.  i have used labview and arduinos for years.
Compiler will not produce result on my UNO, Windows10,  labview 2016
 Arduino IDE 1.6.12 is running and non labview compiler sketches upload and access serial port work with UNO connected to COM12.
 I load Labview compiler example:  Analog Input – Temperature.vi
I run 'compiler verify only'.  It says: compiling and downloading .. finished.
Next I try 'compile and download' (with the IDE Running and on Com port 12.
 No activity occurs on the UNO board light
I select the serial monitor. shows intended characters generated by the  last skch that was running on thd board before I used the labview compiler.
I select arduino code:
Many errors are reported including:
error in analog input--- temperature vi :   function not supported
and many more functions not supported
Should the arduino IDE be running?
December 12, 2016
5:01 am
Please refer to this FAQ regarding your issue.
Also, the Arduino Code option is only for use when porting an Arduino Library to LabVIEW.  Refer to this section in the help manual for more information on the Arduino Code option.
December 12, 2016
10:01 pm
hib
I am trying to run the same example at work on an IDE version  1.6.13.  i get a compile error:
1.0.0.21, Arduino/Genuino Zero (Programming Port)
Verifying...
C:\Users\h5b\AppData\Local\Temp\58e9973bb6e2e908c6c199f5a9d39075.tmp\temp\temp.ino:1:21: fatal error: LVArray.h: No such file or directory
#include "LVArray.h"
please advise how to run this sketch.
December 13, 2016
1:34 am
hib
Now I have two computers unable to run the example sketch Analog input--- temperature vi
On my home computer I uninstalled arduino 1.6.12 and installed 1.6.11.  i uninstalled and reinstalled the arduino compiler for labview.  I get this error.    No such file or directory  #include "LVArray.h"
this is the same error I get on my work computer with arduino 1.6.13 IDE,  this IDE version is supposed to address the problem yo described.
where is the "LVArray.h" file supposed to be located?
please suggest a solution.
December 13, 2016
2:39 am
Take a look on the forum. This post should help.
December 13, 2016
3:50 am
hib
Works great.
thank you.
