Change of PWM frequency possible?
June 23, 2015
11:55 am
11:55 am
ML
June 23, 2015
Hello at all,
I got an Arduino Uno and LabView 2014. I compiled the Arduino with my code so that Pin 9 outputs a PWM Signal.
Now the Frequency is set by default to 500Hz.
Is it possible to change the frequency of the PWM port (Pin 9) of the Arduino Uno with LabView?
I want to change it too 200Hz.
Any ideas are welcome.
Thanks in advance.
ML
June 23, 2015
1:34 pm
1:34 pm
Take a look at the VI Documentation for Analog Write. Also documented here, the PWM frequency using this method is fixed to 490Hz. What you can do is use a timer interrupt and toggle a Digital I/O to get 200Hz. Take a look at the "Interrupt - Timer.vi" example. Hope that helps.
9
Marshalluzd, Cristofer Slz, hoanglong, pujacontrolAdministrators: geadmin: 22, filipealtoe: 96, Steffan: 356
© Simple:Press —
