Compile Error: Must specify exactly one sketch file | Arduino Compatible Compiler for LabVIEW Discussions | Forum
August 18, 2016
11:43 am
klacourt
When attempting to compile code, this error popped up:
"Must specify exactly one sketch file."
The only hint I am finding on this is looking at some possibly related code found here:
https://github.com/arduino/Ard.....arser.java
This code points to the filename being absent or something similar.  Anybody have any idea on this?
August 18, 2016
3:35 pm
It might have to do with your VI name.  What is the name of the VI you are compiling?  Can you post the VI that is causing issues?  Have you tried an example to see if you get the same error?
August 18, 2016
5:09 pm
klacourt
"arduino read data and display test.vi"
It basically reads data from one serial port and writes it to another serial port.  The second serial port has an LCD that accepts serial.  I have this all working from native arduino code, I just wanted to try it from labview.
August 18, 2016
8:08 pm
Did you try either shortening the name/path or compiling one of the included examples?  You can also post your VI so we can take a look.
