Digilent ADC/DAC shield | Arduino Compatible Compiler for LabVIEW Discussions | Forum
July 14, 2015
6:08 pm
GLeMunyan
Forum Posts: 7
Seeing the new release email for Ver....17 release. I went and ordered the Digilent DA/ADC Shield. I have upgraded LabVIEW but I don't see any thing what so ever about how to use the board. I have looked in the current UM, on VI palettes. The most noticeable thing is there are a few pins not aligning when I plug the shield into my Mega 2560. Do I need a Uno board instead?
July 14, 2015
9:52 pm
The Digilent API VIs set was used an example showcasing the new feature that was added to the compiler, which allows users to port existing Arduino libraries to LabVIEW so they can be used with the compiler. More details of that feature can be found on a separate User Guide we have created showing how to do that, that one can access through the user manual. Therefore, the API VIs are not part of the core product (i.e. palette), they reside on the addon folder (refer to the User Guide above for more information on the full path).
As far as using the shield itself, you should probably refer to Digilent's documentation on it (http://www.digilentinc.com/Pro.....LOG-SHIELD). I actually have developed/tested the APIs by using the shield on an Arduino Mega 2560; so I know for a fact it is compatible with the Mega for sure.
Hope this helps
6:41 pm
GLeMunyan
Forum Posts: 7
Fillipe,
Thanks. Found the VIs just where you said and it is in the UM, which I hadn't read. I have 3 projects, one could become a product and there are 2 others which are speculative now but could easily get turned on. I am excited that that there is continuous work to the compiler. Using the Digilent shield gives me a jump start for the speculative projects.
Greg
July 26, 2015
6:46 pm
Awesome. I am glad this can give you a head start on things. If you are making to NIWeek this year, stop by our booth (1004) to say hi. Smile
8:14 pm
GLeMunyan
Forum Posts: 7
This project was dropped but I am now back to it. Cannot get to work.
Using an Arduino Mega 2560 R3 and the Digilent Analog shield. Was using a Mega 2560 R2 - didn't work either
1) Using the example AI shield pass through VI. Compiles and downloads.
2) Using a Virtual Bench to provide waveform out and scope in. Trace the analog input to Pin 2 of ADS8343.
3) But there is no activity on SPI. CS is high and there is no clock. There was no SPI activity with the other Arduino.
What am I doing wrong?
April 11, 2016
8:21 pm
Were you able to see it working if you run the Shipping Arduino Sketch example by Digilent? I would start there to make sure your HW setup is correct.
8:26 pm
If Im not mistaken, the Diligent Analog Shield can only be used with the Uno.  Keep in mind the Uno and Mega have their SPI pins at different locations.  If its this one it says for Uno only.
April 16, 2016
6:53 pm
GLeMunyan
Forum Posts: 7
Steffan, You are correct. I connected to a Uno and it worked fine.
April 17, 2016
8:40 am
scottj
Forum Posts: 28
Hi Steffan,
Good news, some folks have gotten the Analog Shield to work with the Due.  See http://hackingphysics.com/2015.....o-the-due/  ...note the caution about the 3.3V configuration!
I will be spinning this up shortly and will post on how it goes.
May 5, 2016
1:33 am
scottj
Forum Posts: 28
Steffan, the Analog Shield is documented on that product's Github entry as compatible with the Due.  See the ramp.ino example at https://github.com/mwingerson/.....mples/ramp
However, there is a note that the SPI library needs special treatment:
For Arduino DUE using Arduino IDE, SPI needs to be included before
analogShield.
I have not gotten my code to work on the Due, though it works fine with the Uno.  Might this include-order detail be the reason?
Thanks in advance for any guidance or suggestions.
May 5, 2016
11:30 pm
I took a look at the Due example and it does appear it is an SPI library linking issue.  If you are using the included Digilent library translator, it looks like analogShield.h is included before SPI.h so you could easily try switching it there as this suggests.  May be best to get it working in the Arduino IDE first and there were some suggestions about making sure the correct SPI library is linked in too.
June 23, 2016
4:48 pm
GLeMunyan
Forum Posts: 7
Back to trying to get the Digilent Analog Shield working with the Mega 2560. I found this https://github.com/wespo/analogShield. Installed and tested it in Arduino IDE 1.68.
Trying to import it into into the LabVIEW compiler and can't seem to get it. Using the document "Porting an Arduino Library to LabVIEW.
Installed referring to the help topic "Porting an Arduino Library to LabVIEW" here is what I did.
Copied to “[LABVIEWDIR]\vi.lib\Aledyne-TSXperts\Arduino Compatible Compiler for LabVIEW\addons\Digilent Analog Shield” Analog shield master.zip from github.
Unzipped  and also copied to the main folder the .CPP and .h file.
Attached is the Error Screen shot I am getting.
Environment stuff
Arduino IDE 1.6.8
LabVIEW 2015 SP1 32 bit
Arduino compatible compiler for LabVIEW V 1.2.2.21
Windows 8.1 Pro
June 24, 2016
6:03 pm
scottj
Forum Posts: 28
scottj said
Hi Steffan,
Steffan, I've been meaning to update this thread with the good news: The Analog Shield does indeed work brilliantly on the Due with your compiler!  I've achieved 100kHz, 16-bit analog I/O updates with this shield and that marvelous little Arduino.  Lots of possibilities here!
Your suggestion to get it working in the Arduino IDE first is a good one.  Simply putting the SPI.h header first was all that's needed.  The correct library is needed of course, and getting that from https://github.com/wespo/analogshield is a simple matter.
