Displaying values from Arduino on LV soft front panel | Arduino Compatible Compiler for LabVIEW Discussions | Forum
February 18, 2017
10:38 am
tech1962
new to Arduino and this compiler, however experienced with embedded and LV.
Im able to run editted LV programs on my Arduino Uno. Nice.
How do I go about running a program which can display values from the Uno back to the PC based LV SFP ?
I assume the transfer is via the serial port /USB ?
Is there an example that shows a basic display of say analog input voltage on a LV SFP ?
In the compiler example "serial-monitoring-arduino target" is mentioned a HOST PC vi...however I cannot find this.
Perhaps this is the key example I am looking for ?
or is this not possible for an Uno ?
Thanks for any help.
February 18, 2017
7:49 pm
Yes, that is the example you are looking for.
C:\Program Files (x86)\National Instruments\LabVIEW 2014\examples\Aledyne-TSXperts\Arduino Compatible Compiler for LabVIEW\Serial\Monitoring GUI
5:25 am
tech1962
Thanks for the prompt reply.
I had success the first compile..and then I started to make some edits, and ran into this error.
Error 42 occurred at Arduino Compatible Compiler for LabVIEW.lvlib:ArduinoSketchGenerator.vi
I still get this error even after reverting to the original project and code.
I inserted a status indicator on the status output of compiler.vi in host.vi and received :
Verifying...
Uploading...
avrdude: ser_open(): can't open device "\\.\COM7": The system cannot find the file specified.
An error occurred while uploading the sketch
The uno is connected and working.
Is there perhaps some need to clear the port so it can be found ?
Thanks for your help.
