Error Compiling LabVIEW Code to target | Arduino Compatible Compiler for LabVIEW Discussions | Forum
June 3, 2021
10:18 pm
LabVIEW_guru73
Good afternoon,
I have been testing the Arduino Compiler for LabVIEW potentially to be used for deploying applications to the Controllino PLCs.
Using LabVIEW 2020 with the latest Arduino Compiler 1.8.15.
When uploading and deploying applications from LabVIEW using the compiler I am getting error messages from the compiler however it appears that the basic Blink LED is compiling and uploading to the target.
I get the same error when targeting the Controllino target or my Arduino Uno plain board. Not sure what I am doing wrong?
Currently I have the home/student edition of the compiler and working on some demo's and proof of concept applications to determine if I would license the commercial version of the Compiler Toolkit for LabVIEW to create and deploy applications.
Any help would be greatly appreciated!
-73s Steven
June 4, 2021
3:08 pm
Ron1312
Forum Posts: 13
Looks like you haven't fixed "arduino_debug.l4j.ini"  You need to turn debug mode off.
Some time ago the arduino IDE changed the default, so you need to add the line " -DDBUG=false
Thus:
-Xms128M
-Xmx512M
-Dfile.encoding=UTF8
-Djava.net.preferIPv4Stack=true
-DDEBUG=false
June 4, 2021
3:50 pm
LabVIEW_guru73
Ron,
Thank you for your reply, I will check that out. I am assuming that is the Arduino IDE ini file that I need to edit?
June 4, 2021
4:55 pm
Ron1312
Forum Posts: 13
4:39 pm
Alan Kitching
Forum Posts: 9
Hi.  After running the compiler very successfully, I am now getting a fatal error.
This seemed to appear shortly after I made some changes to the location and name of a Global Variable, however, if I run the compiler on an empty VI, containing just an Error Cluster Control wired to an Error Cluster Indicator, this also produces the same error.
The attached file contains the output from the compiler.
Any help would be very much appreciated
July 5, 2022
6:01 pm
It looks like there are multiple definitions of functions being included, possibly from a custom library you have built.  We'll respond to your support request that was received to help you resolve your issue.
July 13, 2022
4:09 pm
Alan Kitching
Forum Posts: 9
Many thanks for the prompt response, Steffan.
I followed you suggestions to remove the duplicate references, and everything is working fine again 🙂
