5:00 pm
Hi.
I have just come back to using the compiler after several months, and find that when I try to compile any LV code, even one of the examples, I get several error messages such as
Error in Digital Output - Blink LED.vi Native function "Wait" not supported
Error in Digital Output - Blink LED.vi "Pin Mode" not supported
I have searched this forum, without any success.
Please could someone tell me where to find help on what I may have broken or am doing wrongly?
Many thanks
5:17 pm
See here:
https://www.geverywhere.com/fo.....uino-code/
You cannot generate Arduino Code. You need to either select Verify, or Compile and Download.
9:24 am
Many thanks for the prompt reply Steffan.
That explains it perfectly, - I should not have been clicking on the Compiler > Arduiono Code option - my mistake.
However, I still have my original problem. - If I take the simplest of programs, say the "Blink LED.vi" from the examples folder and compile and down-load it, the process does not complete. I see the following messages
Running interpreter...Finished!
Generating downloadable program...Finished!
Compiling and downloading...Finished
No further output is generated, and no code is downloaded to my target board.
I am running Arduino IDE Version 1.6.12 under Windows XP - The file "Arduino.exe" is located in C:\Program Files\Arduino\
This configuration has worked perfectly well in the past
Please can you suggest what I may be doing wrong?
Many thanks
Regards Alan K.
5
