Example Compiling error(LabVEIW 2015, Windows7,UNO) | Arduino Compatible Compiler for LabVIEW Discussions | Forum
September 21, 2015
1:23 am
koforever
Hello~
I'm testing several examples.
There are error when compiling below examples
Tone -play song.vi
Digital input - Polling a button.vi
And error message like below.
I'm using LabVIEW 2015 and windows 7.
My arduino is UNO.
Thank you
1.0.0.18, Arduino Uno
"temp.ino" contains unrecognized characters.If this code was created with an older version of Arduino,you may need to use Tools -> Fix Encoding & Reload to updatethe sketch to use UTF-8 encoding. If not, you may need todelete the bad characters to get rid of this warning.
Verifying and uploading...
temp:34: error: stray '\' in program
temp:40: error: stray '\' in program
temp:46: error: stray '\' in program
temp:50: error: stray '\' in program
temp.ino: In function 'void setup()':
temp:34: error: 'ufffd' was not declared in this scope
temp:34: error: expected ')' before 'ufffd'
temp:40: error: expected ')' before 'ufffd'
temp:46: error: expected ')' before 'ufffd'
temp:50: error: expected ')' before 'ufffd'
September 21, 2015
1:29 am
Are you using LabVIEW in English or some other language?
5:29 am
koforever
filipealtoe said
I'm using Korean LabVIEW.
So I changed OS language to English and Decimal symbol.
but It was same.
Lastly I deleted Korean LabVIEW 2015 and Install english LabVIEW.
Compile well and there is no error.
Thank you!~
September 21, 2015
3:28 pm
Ok; thanks for the clarification. That explains why you are seeing the compilation errors. As the User Manual states:
"One of the differences between how LabVIEW and the Arduino Compatible Compiler for LabVIEW work is related to boolean case statements.
Non-English versions LabVIEW will, however, translate to the corresponding localized language the True/False words that define the frame names for a boolean case statement. This causes the LabVIEW Compatible Compiler for LabVIEW to throw a compilation error. "
The two example VIs you referred to have boolean case statements as part of their implementation; therefore these compilation errors are expected. The User Manual suggests a workaround you can implement to avoid this issue. Refer to the "Important Considerations Before Start Creating Arduino VIs" section of the manual.
