Generated Arduino code variable not decleared? the variable are all like "Node853Out" | Arduino Compatible Compiler for LabVIEW Discussions | Forum
February 17, 2022
11:12 am
aliang
Forum Posts: 10
I have successfully ported three drivers before, but when I was porting a TFT driver, I encountered a strange behavior; the variable is not defined before the function call.
#include "LVArray.h"
#include "A4Lhelper.h"
#include
#include
#include
unsigned long color_862;
color_862 = 0;
TFT_eSPI.init();
tft.fillScreen(Node853Out);
The 'color_862' is the variable I need to set to this function, but somehow the Arduino code is not putting the variable in the correct position. Instead, it calls a 'Node853Out', which is not defined in these codes. Can somebody give me a hint? Thanks!
edit1:
This phenomenon seems only to happen with the new driver I'm porting today; calling old drivers I ported before appears still generate valid code.
edit2:
Things got even wilder, and the function doesn't use the data I wired in; it uses error as input now? What have I done? Or what's can I do to fix this problem??
#include
#include
unsigned char Const202;
Const202 = 8;
tft.setTextSize(error_in__no_error__217);
February 17, 2022
6:36 pm
You may be indexing the wrong input as the error in will also come on one of the inputs.  Hard to say without seeing your VI.
February 18, 2022
1:08 am
aliang
Forum Posts: 10
Thank you. Indeed it is an index issue. I was surprised why didn't I meet this kind of problem earlier. I was using the auto index of the LV array index function, which all passed the functional test, and the code all checked out. I was in luck back then, I guess:)
