LoopCount1311 Compiler errors | Arduino Compatible Compiler for LabVIEW Discussions | Forum
May 23, 2015
6:25 pm
RTSLVU
Forum Posts: 21
I am trying to make a simple back and forth flasher for a demo and I keep getting an error on compilation.
Image Enlarger
May 23, 2015
6:33 pm
RTSLVU
Forum Posts: 21
Why does the previous post fail and this works?
Image Enlarger
May 23, 2015
7:29 pm
RTSLVU, thank you very much for submitting your error reports.  We will be analyzing them asap.  It looks like the issue has something to do with wiring the N counter on the inside of the loop.  This may not currently be supported and it appears you found a workaround by simply wiring N from the outside of the loop.  We will post back on our findings and will open a Defect report if it is something we are going to address.
May 24, 2015
5:40 pm
@RTSLVU;
Thanks for submitting the error. I tracked down the issue and fixed it. It will be included in the next release of the compiler. It had to do with connecting the N terminal inside the For Loop. As you pointed out, the workaround until the next release is made available is to wire from outside the loop the same variable that is wired to the N terminal outside the loop.
