Porting C Library: how to configure vilib? | Arduino Compatible Compiler for LabVIEW Discussions | Forum
July 18, 2016
4:33 pm
tNag
Using the template files, I could successfully porting an external C library.
However, if I created folder and files from scratch without using the template, the compiler gave me an error: "Translator.vi" could not be found.
I am not sure if I have correctly setup the vilib (or something else).
Plese advise me.
July 19, 2016
4:14 pm
One piece of advice is to make sure your folder and lvlib are named the same.  If that is not your problem please post your library.
July 21, 2016
8:56 am
tNag
Hi Steffan,
Thank you for the advise. The folder and library names are the same. I have attached the libraries for both cases: one created from the template (good case), and the other from scratch (bad case).
July 26, 2016
9:38 pm
tNag said
Hi Steffan,
Sorry for the late reply on this.  This issue was in a previous post.  If you haven't seen it yet the issue is that you have changed the terminal pattern of your Translator.vi.  You need to maintain the same terminal pattern as the Template example.  This is something we will clarify in the manual.  Thanks.
July 27, 2016
3:45 am
tNag
I have changed the terminal pattern and it worked. Thanks for the advise!
