Porting Ethernet2 library to Labview | Arduino Compatible Compiler for LabVIEW Discussions | Forum
August 1, 2016
7:16 pm
ddowning1327
Forum Posts: 8
Hello, I am attempting to port the Ethernet2 library to labview so I can use an ethernet shield and write code in labview for my Arduino.  I am working on making a VI for the client.println function.  The description says the input int "data" which could be a number or an ascii string.  My question is what should I make that input on the front panel of my VI?  Thanks for the help ahead of time.
August 2, 2016
1:29 am
That means the Arduino function supports both an int or string datatype (it is auto adapting).  So you could create 2 VIs if you want, one with a numeric control and one with a string.  Or just create the one you need if you don't require both.
August 2, 2016
4:31 pm
ddowning1327
Forum Posts: 8
Ok thanks, that makes sense, I will do that.
January 19, 2018
9:29 am
alenthomas
Hello, were you able to successfully port the Ethernet library to LabVIEW to use the Ethernet shield?? Please could you share?
January 19, 2018
12:56 pm
ddowning1327
Forum Posts: 8
Hello Alenthomas, no I was never able to make this work.  In all fairness, I barely got to work on it because my employer did not want me to spend time on it.  I use the programmable wireless stamps (PWS) at home and there are already nice VIs for that.  I'm not sure if TSXperts is still in business but they were considering making VIs for this library.  That would be great.
April 21, 2018
1:44 pm
James
hello
Did you solve the problem? would you share it if you solved it?
January 13, 2020
4:25 am
James said
hello
An Ethernet Addon has been created and posted here:
https://www.geverywhere.com/et.....net-addon/
