11:52 am
December 5, 2019
Hello.
I am now trying to read MX055 sensor Magnetometer by I2C Communication.
It is very appreciated if you can share your experience or give me some advice.
It has Accl and Gyro meter also.
Code for Accl and Gyro reading works fine but have difficulty in reading Magnetometer.
I want to confirm use of "I2C write Array" function.
For example to reproduce the sketch below, how should I send data to "I2C write Array" function in LabVIEW ?
I attached an image file I am trying.
Wire.beginTransmission(Addr_Mag);
Wire.write(0x4B); // Select Mag register
Wire.write(0x83); // Soft reset
Wire.endTransmission();
delay(100);
Attached below is a whole sample code for this sensor.
// AE-BMX055 Arduino UNO //
// VCC +5V //
// GND GND //
// SDA A4(SDA) //
// SCL A5(SCL) //
#include<Wire.h>
// BMX055
#define Addr_Accl 0x19 //
// BMX055
#define Addr_Gyro 0x69 // (JP1,JP2,JP3 = Openの時)
// BMX055
#define Addr_Mag 0x13 // (JP1,JP2,JP3 = Openの時)
float xAccl = 0.00;
float yAccl = 0.00;
float zAccl = 0.00;
float xGyro = 0.00;
float yGyro = 0.00;
float zGyro = 0.00;
int xMag = 0;
int yMag = 0;
int zMag = 0;
// Wire(Arduino-I2C) func initialization
Wire.begin();
Serial.begin(9600);
//BMX055 initialization
BMX055_Init();
delay(300);
Serial.println("--------------------------------------");
//BMX055 Read Accl
BMX055_Accl();
Serial.print("Accl= ");
Serial.print(xAccl);
Serial.print(",");
Serial.print(yAccl);
Serial.print(",");
Serial.print(zAccl);
Serial.println("");
//BMX055 Read Gyro
BMX055_Gyro();
Serial.print("Gyro= ");
Serial.print(xGyro);
Serial.print(",");
Serial.print(yGyro);
Serial.print(",");
Serial.print(zGyro);
Serial.println("");
//BMX055 Read Magnet
BMX055_Mag();
Serial.print("Mag= ");
Serial.print(xMag);
Serial.print(",");
Serial.print(yMag);
Serial.print(",");
Serial.print(zMag);
Serial.println("");
delay(1000);
void BMX055_Init()
Wire.beginTransmission(Addr_Accl);
Wire.write(0x0F); // Select PMU_Range register
Wire.write(0x03); // Range = +/- 2g
delay(100);
Wire.write(0x10); // Select PMU_BW register
Wire.write(0x08); // Bandwidth = 7.81 Hz
delay(100);
Wire.write(0x11); // Select PMU_LPW register
Wire.write(0x00); // Normal mode, Sleep duration = 0.5ms
delay(100);
Wire.beginTransmission(Addr_Gyro);
Wire.write(0x0F); // Select Range register
Wire.write(0x04); // Full scale = +/- 125 degree/s
delay(100);
Wire.write(0x10); // Select Bandwidth register
Wire.write(0x07); // ODR = 100 Hz
delay(100);
Wire.write(0x11); // Select LPM1 register
Wire.write(0x00); // Normal mode, Sleep duration = 2ms
delay(100);
delay(100);
Wire.write(0x01); // Soft reset
delay(100);
Wire.write(0x4C); // Select Mag register
Wire.write(0x00); // Normal Mode, ODR = 10 Hz
Wire.write(0x4E); // Select Mag register
Wire.write(0x84); // X, Y, Z-Axis enabled
Wire.write(0x51); // Select Mag register
Wire.write(0x04); // No. of Repetitions for X-Y Axis = 9
Wire.write(0x52); // Select Mag register
Wire.write(0x16); // No. of Repetitions for Z-Axis = 15
void BMX055_Accl()
int data[6];
for (int i = 0; i < 6; i++)
Wire.write((2 + i));// Select data register
Wire.requestFrom(Addr_Accl, 1);// Request 1 byte of data
// Read 6 bytes of data
// xAccl lsb, xAccl msb, yAccl lsb, yAccl msb, zAccl lsb, zAccl msb
if (Wire.available() == 1)
data[i] = Wire.read();
// Convert the data to 12-bits
xAccl = ((data[1] * 256) + (data[0] & 0xF0)) / 16;
if (xAccl > 2047) xAccl -= 4096;
yAccl = ((data[3] * 256) + (data[2] & 0xF0)) / 16;
if (yAccl > 2047) yAccl -= 4096;
zAccl = ((data[5] * 256) + (data[4] & 0xF0)) / 16;
if (zAccl > 2047) zAccl -= 4096;
xAccl = xAccl * 0.0098; // renge +-2g
yAccl = yAccl * 0.0098; // renge +-2g
zAccl = zAccl * 0.0098; // renge +-2g
void BMX055_Gyro()
int data[6];
Wire.write((2 + i)); // Select data register
Wire.requestFrom(Addr_Gyro, 1); // Request 1 byte of data
// xGyro lsb, xGyro msb, yGyro lsb, yGyro msb, zGyro lsb, zGyro msb
// Convert the data
xGyro = (data[1] * 256) + data[0];
if (xGyro > 32767) xGyro -= 65536;
yGyro = (data[3] * 256) + data[2];
if (yGyro > 32767) yGyro -= 65536;
zGyro = (data[5] * 256) + data[4];
if (zGyro > 32767) zGyro -= 65536;
xGyro = xGyro * 0.0038; // Full scale = +/- 125 degree/s
yGyro = yGyro * 0.0038; // Full scale = +/- 125 degree/s
zGyro = zGyro * 0.0038; // Full scale = +/- 125 degree/s
void BMX055_Mag()
int data[8];
for (int i = 0; i < 8; i++)
Wire.write((0x42 + i)); // Select data register
Wire.requestFrom(Addr_Mag, 1); // Request 1 byte of data
// xMag lsb, xMag msb, yMag lsb, yMag msb, zMag lsb, zMag msb
// Convert the data
xMag = ((data[1] <<8) | (data[0]>>3));
if (xMag > 4095) xMag -= 8192;
yMag = ((data[3] <<8) | (data[2]>>3));
if (yMag > 4095) yMag -= 8192;
zMag = ((data[5] <<8) | (data[4]>>3));
if (zMag > 16383) zMag -= 32768;
14
