8:41 am
March 23, 2015
I'm already using the following I/O lines on my PWS Stamp board:
GPIO5/GPIO13 = Soft Serial Tx/Rx
GPIO12 = 1-wire Temperature Sensor Input
GPIO14 = I2C Clock Output
GPIO2 = I2C Data In/Out
GPIO1/GPIO3 = USB Programming Port Tx/Rx
So this leave me with only two I/O lines left
GPIO16 = Used to control a LED on the board and cannot be used as an interrupt so I cannot use this.
This leaves only pin GPIO15 to monitor the Open drain output Interrupt output from a MAX7318 IC. I have a 10K tie-up resistor to 3.3V on this line, but according to the PWS schematics there is a 12K Pull-down to ground and sure enough I end up with a voltage divider on this line of about 1V. Also this seems to affect the programming of the PWS Stamp and this line is labelled "CS" so can I use it as a general purpose input or is it used by the PWS Stamp for something else?
Have a run out of I/O?
Chris
16
