SD Card Library | Arduino Compatible Compiler for LabVIEW Discussions | Forum
SD Card Library
September 13, 2016
10:26 pm
LDBM
Forum Posts: 11
I am wondering which SD card library is used to build the SD card VIs? SD.h ?.  Going through some forums, it appears that SD.h (the standard library) returns errors if a SD function is called following a sleep-awake cycle on an arduino target, which makes saving data in between sleep intervals not doable.  Is it the same potential issue on the PWS ? Thanks.
ldbm.
September 13, 2016
11:04 pm
Yes, it is SD.h.
September 14, 2016
10:39 pm
LDBM
Forum Posts: 11
What about the PWS?  thx.
L.
September 14, 2016
10:42 pm
You will have to contact TSXperts regarding the PWS.
January 20, 2017
11:00 am
donnacarter0103
US
LDBM said
ldbm.
From my point of you, SD.h is used to build the SD card VIs.
