SD Card List Fucntion | Arduino Compatible Compiler for LabVIEW Discussions | Forum
January 28, 2017
10:20 am
SimonCee
Forum Posts: 10
I'm a LabVIEW developer and this is my first foray into Arduino and LVforArduino.
I'm building a simple access gateway to store and retrieve data files wirelessly from an Arduino target.  There doesn't appear to be a SD card 'File' or 'Directory List' function in the LabVIEW Palette and I need this as part of the application.
There is a function in SD.h called 'openNextFile' and this is the root of a 'List Files' function.  I'm aware that the LVforArduino libraries are built around SD.h so does that mean that 'openNextFile' is there, but just not revealed as a VI call?  If it is what do I need to do to make that call.
Help and insight would be much appreciated.
TVM
SimonC
January 28, 2017
11:41 am
In general terms, the Compiler allows any existing Arduino library to be ported and used in LabVIEW via the creation of a set of user API VIs that wrap around the Arduino library functions. Take a look at the Product User Manual as there is a user guide showing how one can do that. So, if a given library function hasn't been exposed as part of the Compiler itself, one can potentially use this method to create API VIs that do. Hope this helps.
