SD file exists function | Arduino Compatible Compiler for LabVIEW Discussions | Forum
March 14, 2016
4:02 pm
codyd87
Forum Posts: 7
Does anybody use the SD library?  I am having problems calling the SD file Exists function.  Do I have to download anything else in to my library to make it work?
Screenshot-2016-03-14-09.59.38.pngImage Enlarger
March 14, 2016
5:17 pm
Ah, thanks for pointing that out.  The SD File Exists API was supposed to be removed some time ago but looks like it got left in there.  Take a look at the SD card examples.  You don't need this API.  If you are trying to determine if a file is present you can use the SD File Open API, open a file as Read Only, and check the boolean opened result.  Hope that helps.
