Seeeduino XIAO Neopixel compilation failure | Arduino Compatible Compiler for LabVIEW Discussions | Forum
March 31, 2021
7:21 pm
Ron1312
Forum Posts: 13
I've started playing with a Seeeduino XIAO
 Sadly, it fails to compile RGB LED strip vi's
Running Arduino 1.8.13
Latest versions of needed libraries installed
XIAO device driver installed.
The Adafruit_Neopixel example: "strandtest_wheel"
loads and runs from Arduino IDE.
The LabVIEW/Arduino "blink" example compiles/loads/runs
Other examples also compile/load, except for the "RGB LED strip" examples.
The "RGB LED strip" vi's fail to compile.
Here's a sample of the compile-fail/error-output I've been getting:
1.0.0.21, Seeeduino XIAO
Verifying...
2021-03-30T16:55:28.806Z INFO c.a.u.n.HttpConnectionManager:153 [cc.arduino.packages.discoverers.serial.SerialDiscovery] Connect to https://builder.arduino.cc/builder/v1/boards/0x1A86/0x7523, method=GET, request id=9B5EDA85C28045EA
2021-03-30T16:55:29.167Z INFO c.a.u.n.HttpConnectionManager:157 [cc.arduino.packages.discoverers.serial.SerialDiscovery] Request complete URL="https://builder.arduino.cc/builder/v1/boards/0x1A86/0x7523", method=GET, response code=404, request id=9B5EDA85C28045EA, headers={null=[HTTP/1.1 404 Not Found], Cache-Control=[no-cache, no-store, must-revalidate], Server=[nginx], Connection=[keep-alive], Vary=[Origin], Pragma=[no-cache], Expires=[0], Content-Length=[0], Date=[Tue, 30 Mar 2021 16:55:31 GMT]}
2021-03-30T16:55:29.168Z WARN p.a.h.BoardCloudResolver:64 [cc.arduino.packages.discoverers.serial.SerialDiscovery] Fail to get the Vid Pid information from the builder response code=404
2021-03-30T16:55:29.182Z INFO c.a.u.n.HttpConnectionManager:153 [cc.arduino.packages.discoverers.serial.SerialDiscovery] Connect to https://builder.arduino.cc/builder/v1/boards/0x1A86/0x7523, method=GET, request id=83CFA36AF85B48D3
2021-03-30T16:55:29.220Z INFO c.a.u.n.HttpConnectionManager:157 [cc.arduino.packages.discoverers.serial.SerialDiscovery] Request complete URL="https://builder.arduino.cc/builder/v1/boards/0x1A86/0x7523", method=GET, response code=404, request id=83CFA36AF85B48D3, headers={null=[HTTP/1.1 404 Not Found], Cache-Control=[no-cache, no-store, must-revalidate], Server=[nginx], Connection=[keep-alive], Vary=[Origin], Pragma=[no-cache], Expires=[0], Content-Length=[0], Date=[Tue, 30 Mar 2021 16:55:31 GMT]}
2021-03-30T16:55:29.230Z WARN p.a.h.BoardCloudResolver:64 [cc.arduino.packages.discoverers.serial.SerialDiscovery] Fail to get the Vid Pid information from the builder response code=404
C:\Users\Frog\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp: In member function 'void Adafruit_NeoPixel::show()':
C:\Users\Frog\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:839:3: error: 'Pio' was not declared in this scope
Pio *port;
What's going wrong? Any fix?
April 2, 2021
3:47 pm
Looks like the Adafruit NeoPixel library used by the compiler does not support the Seeduino.  If you look at the offending line the Pio datatype is specific for the Due but its hitting the #else case here since the library probably doesn't know about this board.  Take a look at a current release of the library, they may have included support for it.
https://github.com/adafruit/Ad.....t_NeoPixel
April 2, 2021
7:34 pm
Ron1312
Forum Posts: 13
I'm confused. The Adafruit_Neopixel example "strandtest_wheel" calls the same library and loads/runs with the Arduino IDE without errors,
thus I'd expect the LabVIEW compiler to work as well.
I have checked and I do have the latest version of the library installed.
I don't know if this helps, but here's the rest of the error output:
C:\Users\Frog\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:839:19: error: 'port' was not declared in this scope
Pio *port;
C:\Users\Frog\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:839:19: note: suggested alternative: 'Port'
Pio *port;
Port
C:\Users\Frog\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:843:3: error: 'pmc_set_writeprotect' was not declared in this scope
pmc_set_writeprotect(false);
C:\Users\Frog\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:844:3: error: 'pmc_enable_periph_clk' was not declared in this scope
pmc_enable_periph_clk((uint32_t)TC3_IRQn);
C:\Users\Frog\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:845:16: error: 'TC1' was not declared in this scope
TC_Configure(TC1, 0,
C:\Users\Frog\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:845:16: note: suggested alternative: 'TC3'
TC3
C:\Users\Frog\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:846:5: error: 'TC_CMR_WAVE' was not declared in this scope
TC_CMR_WAVE | TC_CMR_WAVSEL_UP | TC_CMR_TCCLKS_TIMER_CLOCK1);
C:\Users\Frog\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:846:19: error: 'TC_CMR_WAVSEL_UP' was not declared in this scope
C:\Users\Frog\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:846:19: note: suggested alternative: 'TCC_WAVE_SWAP'
TCC_WAVE_SWAP
C:\Users\Frog\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:846:38: error: 'TC_CMR_TCCLKS_TIMER_CLOCK1' was not declared in this scope
C:\Users\Frog\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:845:3: error: 'TC_Configure' was not declared in this scope
C:\Users\Frog\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:847:3: error: 'TC_Start' was not declared in this scope
TC_Start(TC1, 0);
C:\Users\Frog\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:847:3: note: suggested alternative: 'va_start'
TC_Start(TC1, 0);
va_start
C:\Users\Frog\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:850:38: error: 'const PinDescription {aka const struct _PinDescription}' has no member named 'pPort'; did you mean 'ulPort'?
port = g_APinDescription[pin].pPort; // declarations above. Want to
ulPort
C:\Users\Frog\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:878:18: error: 'TC_CCR_CLKEN' was not declared in this scope
*timeReset = TC_CCR_CLKEN | TC_CCR_SWTRG;
C:\Users\Frog\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:878:18: note: suggested alternative: 'TC_CTRLC_CPTEN'
TC_CTRLC_CPTEN
C:\Users\Frog\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:878:33: error: 'TC_CCR_SWTRG' was not declared in this scope
C:\Users\Frog\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:878:33: note: suggested alternative: 'TC_CTRLA_SWRST'
TC_CTRLA_SWRST
C:\Users\Frog\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:888:3: error: 'TC_Stop' was not declared in this scope
TC_Stop(TC1, 0);
C:\Users\Frog\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp:888:3: note: suggested alternative: 'CDC_Setup'
TC_Stop(TC1, 0);
CDC_Setup
Here's the Temp "ino" file from this failed test:
[lvtemporary_603808(LED-setup).ino]
#include "LVArray.h"
#include "A4Lhelper.h"
#include <Adafruit_NeoPixel.h>
Adafruit_NeoPixel * _LEDpix[3];
unsigned char Const234;
unsigned short Const181;
unsigned char Const152;
unsigned short Const127;
Const234 = 4;
Const181 = 3;
Const152 = 0;
Const127 = 60;
_LEDpix[Const152] = new Adafruit_NeoPixel(Const127,Const234,Const181);
_LEDpix[Const152]->begin();
April 5, 2021
3:14 pm
The Compiler automatically installs the library included with the package located here:
[LABVIEWDIR]\vi.lib\Aledyne-TSXperts\Arduino Compatible Compiler for LabVIEW\Arduino Libraries
You would have to replace the NeoPixel library at this location.
April 6, 2021
1:51 am
Ron1312
Forum Posts: 13
Oh "bleep!" that seems to have looped me back to my previous post:
sp_TopicIcon
Weird stuff! I'm going to need some time to sort things out before I can respond....
April 6, 2021
2:27 am
Ron1312
Forum Posts: 13
Quick summery: The after updating  Adafruit_Neopixel the XIAO program complied, but the colors were wrong (as per my previous post), and wrong for all my previous Arduino programs/devices. Replacing the new/old libraries did not restore things to normal. Reinstalling both the compiler and the Arduino IDE (including clearing the <user>/Documents/Arduino/libraries..., and //AppData/Local/Arduino15) .. will restore the system to a normal state. [more later... ]
April 7, 2021
4:40 pm
Ron1312
Forum Posts: 13
Solved ...sort of.
It seems the RGB LED strip vi's are not compatible with the Adafruit_Neopixel libraries after v1.0.2. Best I can tell Adafruit added WRGB string support in v1.0.3 and (I suspect) in doing such changed the color-channel addresses.
Note: Adafruit now has more than 20 versions of the Neopixel library (now up to v1.7.0) and none above v1.0.2 seem to work properly with the compiler's RGB LED strip vi's. I tested a number of them and from v1.0.3 on the only color available seems to be green.
On a positive note, the v1.0.2 library supports the Seeeduino XIAO's SAMD21 .. so my LED strip vi's load and run properly.
Wondering... are there any WRGB LED pixel-strip tools for this compiler out there somewhere?
