SPI Transfer vi CS pin not doing anything | Arduino Compatible Compiler for LabVIEW Discussions | Forum
March 1, 2017
12:53 pm
ddowning1327
Forum Posts: 8
Hello, I am trying to communicate with an AD board via SPI but I am having a problem with the SPI Transfer vi.  I set the CS pin to 8 but pin 8 does not do anything when I call the vi.  I got around this by manually pulsing the CS pin before calling the SPI Transfer vi.  Has anyone else had this problem?
March 3, 2017
5:40 pm
What type of board are you using?  If it is the Due, there are only certain allowable CS pins and 8 is not one of them.  The only pins allowed on the Due are 4, 10, 52, and 54.  Otherwise, for standard Arduino boards this API just configures it as a digital I/O as you are doing manually, so you should not have to do this and pin 8 should work.  Take a look at the included SPI example and the help for SPI Open Express.vi which explains how the CS works.
March 3, 2017
7:33 pm
ddowning1327
Forum Posts: 8
Yes, you are correct.  I am using the Due so I had to switch it to pin 10.  Thank you.
