Support for ATMega 328PB | Arduino Compatible Compiler for LabVIEW Discussions | Forum
November 29, 2019
4:25 pm
Alan Kitching
Forum Posts: 9
Hi.  I have an application which needs two I2C ports, but as the space and cost do not warrant the use of the Arduino Due, I would like to use the Atmel AT Mega 328PB.
Is this supported by the Arduino Compiler, or might it be in near future?
If not, can anyone suggest the best workaround?  I'm not sure whether "bit-banging" is possible under LabVIEW.
December 1, 2019
3:38 am
Any reason you can't use only 1 I2C port?  I2C is a bus so you can have multiple slaves since its an address based architecture.  The I2C port supports multiple masters as well if thats the issue.
