This compiler does not support FGV? | Arduino Compatible Compiler for LabVIEW Discussions | Forum
July 16, 2016
10:57 am
scadao
Forum Posts: 24
Development environment:
Windows 7 SP1; LabVIEW 2014 SP1; Arduino IDE V1.6.9; Compiler V1.0.0.21; Arduino DUE Board
This compiler does not support FGV(Functional Global Variable)? I use the serial test with FGV.vi, found no response. Examples are as follows:
July 16, 2016
11:45 am
scadao
Forum Posts: 24
Now I can only use global variables instead of FGV:
July 16, 2016
8:31 pm
That is correct, unfortunately you cannot use an uninitialized shift register in a subVI making an FGV non-functional.  The reason why is the way subVIs and memory optimization is handled by the Compiler.  SubVI variables are handled like C function local variables meaning they are automatic duration variables (refer to the Important Considerations section of the user manual).  Automatic duration variables are stored on the stack and are released when the subVI returns to preserve memory usage.  But as you noticed, you can replace with a global variable to force the Compiler to allocate the memory for that variable statically.
July 17, 2016
2:58 am
scadao
Forum Posts: 24
Thank Steffan! I understand that if the subVI use an uninitialized shift register, the compiler does not support.
