Troubles with the download to the arduino | Arduino Compatible Compiler for LabVIEW Discussions | Forum
August 15, 2016
4:29 pm
jetza
Forum Posts: 7
I'm having troubles with downloading my application to the Arduino.
The compiler doesn't download my program to the Arduino. I'm trying to put the examples in the device but I can't but the compiler recognize my arduino uno and I can see it on the serial monitor.
When I try to "Compile and Download" it show me this, but the application didn't download to the Arduino.
Image Enlarger
The licence is being shared by two machines.
Thank you in advance
August 16, 2016
4:33 am
We have not seen this before but it is not a licensing issue.  Do you see the TX/RX LEDs light up on the board while programming?  Can you confirm first that you can program a simple example through the Arduino IDE itself?  Make sure you select the same COM port when you try it.
August 16, 2016
6:38 pm
jetza
Forum Posts: 7
In fact I can program through Arduino IDE but not through Labview Compiler for Arduino. And when I try to program with the Labview Compiler the lights of TX/RX leds never light up, that's how I know that wasn't communication between them.
I program the analog serial example on the Arduino with the Arduino IDE and then I use the serial monitor in Labview Compiler and I can see it with no problems. So I don't know what is happening.
I've also desinstalled the software and reinstalled it but I have the same problem.
August 17, 2016
6:27 am
That is strange.  Can you tell us what versions you are using for the following?
Arduino IDE
LabVIEW (looks like 2014 32-Bit?)
Also, can you confirm that your Sketchbook location in the Arduino IDE preferences is set to the following:
C:\Users\USER\Documents\Arduino
August 17, 2016
3:13 pm
jetza
Forum Posts: 7
Well
I have this versions:
Arduino IDE 1.6.8
Labview 2014 32 bit, but my PC is 64 bits
Arduino Compatible Compiler for LabView 1.0.0.19
And the location of the Sketchbook is : C:\Users\Hector\Documents\Arduino
August 17, 2016
3:20 pm
Please update to the latest Compiler version and try again. There were some changes made in 1.0.0.20 to support a change made to the Arduino IDE regarding where board packages are installed. See release notes. This may be your issue.
August 17, 2016
4:38 pm
jetza
Forum Posts: 7
On the VI package manager the last version avaible is 1.0.0.19
Where can I download the 1.0.0.20 version?
Thank you
August 17, 2016
4:39 pm
You want the latest (1.0.0.21).  You will be notified that an upgrade is available if you open VI Package Manager.
August 17, 2016
5:47 pm
jetza
Forum Posts: 7
Now I upgraded to the latest version and the issue remains.
August 17, 2016
5:59 pm
Ok. Can you try Compile only (not compile and download) and post what you get in the Compiler Window?
August 17, 2016
6:09 pm
jetza
Forum Posts: 7
Yes
Image Enlarger
August 17, 2016
6:17 pm
Please email support@geverywhere.com and we will try to help you debug this matter.
August 17, 2016
7:02 pm
jetza
Forum Posts: 7
Ok
I've already sent the mail.
Thank you
