User defined libraries | Arduino Compatible Compiler for LabVIEW Discussions | Forum
August 13, 2016
6:30 am
IB82
I am created a user defined libraries and my first try was to create a DueRTC library. I read the manual and set up the library step by step. First I created Vis for four functions and mapped the inputs and outputs in the translator Vi. I am created a test Vi and generated c code as described  in the user manual, every think works pretty well after some debugging iterations! I tried to copy the generated code to arduino IDE and start compiling it and it was possible without errors. But when I tried to compile the Vi from LabVIEW, it crashes after a couple of minutes.
But what did I wrong?
Thanks for your help
Ingo
August 13, 2016
5:02 pm
Please post your library and the error you are getting so we can help you.
August 18, 2016
5:33 am
IB82
Hello Steffan,
thanks for assistance. I tried to get all data and error messages for a reply. And I detected the issue by myself. Once Labview crashed and some changes wasn't saved. There was must two commas missing the in generated c-code. Now everything working fine and I am able to use the library.
Regards,
Ingo
